It is currently October 23rd, 2026, 6:11 am
 Post subject: setInterval Function
PostPosted: September 10th, 2012, 11:16 pm
i can't get the function work. Could somebody show me an working example of the setInterval(name,time); function?
 Post subject: Re: setInterval Function
PostPosted: September 11th, 2012, 3:00 am
hi , vlad setInterval function is not available in XWidget , you can use a timerCore to replace it
PostPosted: September 11th, 2012, 4:34 am
It's cool man, i had figured it out.
Just use setTimeout function like this
// ms = 1000 / fps
// 1000 / 40(fps) = 25(ms)
var timeMs = 25;
setTimeout("moveButton",timeMs);
function moveButton()
      displayAnimation();
And i even managed to play / stop animation on click. 8-)
var timeMs = 25;
start();
      if ( ! looping ) return;
      displayAnimation();
function start()
      if ( looping ) return;
      looping = true;
function stop()
      looping = false;
Users browsing this forum: No registered users and 64 guests
