It is currently October 23rd, 2026, 6:11 am
 Post subject: getObject by id (tag)
PostPosted: September 5th, 2012, 7:47 am
Need a help :)
Please, explain how to get Object by tag number, then set param for this object... or get by children number from widget...
Is't possible? or I must use switch - case and set dynamic number to the object name?
PostPosted: September 6th, 2012, 12:04 am
sorry for my poor English , i can't understand the question, do you want
var a = image1.tag
image1.tag=2
PostPosted: September 6th, 2012, 2:59 am
I want to get Image with specific tag, and set Src for this image.
for example: Image.attr(tag=i).Src = Value; Or widget.children[i].Src = Value;
or can I push all object's children to the array? I think not..
I found this solution is working for me:
switch(i)
      case 1: image1.Src = images[i].ico+'.png'; break;
      case 2: image2.Src = images[i].ico+'.png'; break;
      case 3: image3.Src = images[i].ico+'.png'; break;
      case 4: image4.Src = images[i].ico+'.png'; break;
      case 5: image5.Src = images[i].ico+'.png'; break;
PostPosted: September 6th, 2012, 5:00 am
switch(i)
maybe it will help
eval("image"+i).Src= images[i].ico+'.png';
PostPosted: September 6th, 2012, 5:38 am
Very helpful, thank you :)
Users browsing this forum: No registered users and 64 guests
