It is currently October 23rd, 2026, 2:56 am
 Post subject: How get event target?
PostPosted: September 2nd, 2012, 1:56 am
When im pulling the "Sender" inside the function i get an error. "function menuItemOnMouseEnter(Sender)"
    //print(Sender); - prints null (Nothing)
    print(Sender.toString()); // I get a weird character.
    //print(Sender.Target); - prints null (Nothing)
    ...myCode
Apparently the Sender has some sort of Target but i didn't found any explanation about event / Senders online.
If somebody could name the variable name (if such exist's) it will be very helpful to me.
PostPosted: September 2nd, 2012, 6:15 pm
print(Sender.name)
PostPosted: September 3rd, 2012, 1:12 am
For the code:
function menuItemOnMouseMove(Sender)
(line 35)                print(Sender.name);
(line 36)                Sender.Scale = 2;
(line 37)                print(Sender.Scale);
I get the following debug error.
[19:05:47 431]: Widget Debug has ShutDown
[19:05:47 371]: Widget Hide (OnHide)
[19:05:47 222]: Widget is Closing... (OnClose)
[19:05:46 380]: Menu Popup (OnPopupMenu)
[19:05:44 430]: [Script Error (line:37,char:6) ]: EVariantTypeCastError Could not convert variant of type (Dispatch) into type (OleStr)
[19:05:44 428]: print: crclMenuSelectCPU
[19:05:44 138]: Mouse Enter Widget Window (OnEnter)
The problem when line 36 is executed the object won't change his scale value.
PostPosted: September 3rd, 2012, 4:38 pm
Hi, What is the "menuItem" ?
Or, you can write this:
Sender.Scale.X = 2;
Sender.Scale.Y = 2;
PostPosted: September 3rd, 2012, 10:55 pm
Thank you tony so much!!!!
Seance there is no any explanation about how to use scale i had assumed it a scalar. Now when i know its a vector quantity i finality get the result i was expecting for.
Users browsing this forum: Bing [Bot] and 92 guests
