It is currently June 12th, 2025, 9:18 am
 Post subject: xWidget Syntax Summary
PostPosted: August 7th, 2012, 8:51 am
I made a summary document of the syntax needed for XWidgets as there is no documentation. It is basically a human readable version of the code completion text sorted and classified. I hope it is helpful.
File comment: xWidget Syntax Summary
xWidget_Syntax.zip [6.22 KiB]
Downloaded 942 times
PostPosted: August 7th, 2012, 5:53 pm
Thank you :)
PostPosted: August 7th, 2012, 11:10 pm
Thank you very much :)
A few are still not readable, can you assist ?
GetIni(¼üÃû,ĬÈϼüÖµ)
GetMemo(¼üÃû,ĬÈϼüÖµ)
GetValue(¼üÃû,ĬÈϼüÖµ)
GetiniValue(ÎļþÃû,½ÚµãÃû,¼üÃû,ĬÈϼüÖµ)
SetIni(¼üÃû,¼üÖµ)
SetIniValue(ÎļþÃû,½ÚµãÃû,¼üÃû,¼üÖµ)
SetMemo(¼üÃû,¼üÖµ)
Setvalue(¼üÃû,¼üÖµ)
Also, can anyone tell me why there are so many in the code auto complete window that appear like this ?
It would be great if you could read them all in the code auto comple window without having to refer to this file.
Thanks again
PostPosted: August 29th, 2012, 6:44 pm
GetIni(¼üÃû,ĬÈϼüÖµ)
SetIni(¼üÃû,¼üÖµ)
SetMemo(¼üÃû,¼üÖµ)
Setvalue(¼üÃû,¼üÖµ)
Thanks again
because the original character is Chinese
such as this one
Users browsing this forum: No registered users and 13 guests
